04-20-2005 12:03 PM
04-21-2005 04:37 PM
04-21-2005 06:15 PM
04-22-2005 12:03 PM
04-25-2005 08:45 AM
04-25-2005 10:47 AM
04-25-2005 12:55 PM
04-25-2005 05:36 PM
03-13-2023 03:27 AM - edited 03-13-2023 03:40 AM
@Alan_L wrote:
I've attached a screenshot of an example VI that implements synchronization, internal 4mA excitation, and AC coupling across three boards. As you can see, all of the devices can be included in a single DAQmx task. As long as one of the devices is in slot 2 of your chassis (the only slot capable of driving the star trigger), this will do the trick.
Reviving this thread - is this still valid in 2023? I have trouble adding two NI-4472, which are now considered legacy hardware, to one DAQmx task. I simply followed the provided screenshot, I connected one of the modules to 2nd slot while the other is in slot 7 and I get the error -89136 (route cannot be satisfied because the hardware doesn't support it) on DAQmx Start Task:
Property: SampClk.Timebase.Src
Source Device: PXI1Slot2
Source Terminal: SampleClockTimebase
I have never run into synchronisation problems so far..
03-13-2023 05:33 AM
I don't use the 44xx series of boards, but have you tried routing the SampleClock itself, rather than the SampleClockTimebase used to derive it?
-Kevin P
