System config files for Labview App
In Win 7, I am building a Labview project.  Where should I store the user selected system specific configuration files for the app operation?  Things like data directories, log file directories, etc
Message 1 of 8
(2,721 Views)
If you mean your own build application
WHat I do in my projects is the following :
- LabVIEWs ini file in the same folder as exe
- Log files in directory logfiles next to exe
- other data files like settings, configuration etc in a datafolder next to the exe
If you mean with your source code
- create folders for every type of VI : globals, controls(typedef), subVI, FGLB, ...
- create a datafolder for your datafiles your using
- create logfolder for your logfiles
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 8
(2,712 Views)
With WIn 7 though the default app (C:\Prog Files X86\My App) are write protected to the directories now.  In order to write files to it I have to change permissions when I create the directories.
Message 3 of 8
(2,707 Views)
Whatfor do you want to store files?  An application or your source code
Kind regards,
- Bjorn -
Message 4 of 8
(2,703 Views)
variables that need to be stored to disk for later recall during program operation instead of maintaining globals of them
Message 5 of 8
(2,699 Views)
Use the "Get System Directory" VI to choose the most appropriate folder.  For data which you only need until your program finishes, I'd use the "User Temporary" folder.
Mark Moss
Electrical Validation Engineer
GHSP
Message 6 of 8
(2,696 Views)
Thats a good one but I am more interested in storing things after the app is shut down so the user doesnt have to re-enter it every time he runs teh app.  Things like where data directories are.
Message 7 of 8
(2,688 Views)
Use OpenG  Variant Configuration file vis. Very handy.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
Message 8 of 8
(2,676 Views)
