TCP-IP connection ID doesn't work after being assigned to a global
I'm not sure the device makes a difference. It works as expected over a windows command line telnet session or in a Tera Term session (no repeating of history after each write and read). It is a radio that provides a wireless path for ethernet.
Message 21 of 25
(1,009 Views)
Writing to the TCP-IP socket VISA clears the read buffer. Running 'Clear VISA' does not. Wheh, that means the solution is workable.
Message 22 of 25
(996 Views)
And that's why I asked for the device.
TCP/IP Socket and TCP/IP Instrument classes have slightly different properties.  It looks like you discovered correctly that you need a socket.
The details are not important and way more that I care to dive into ( I'd just get a bunch of TL;DR replies anyhow so dig into the help file and google your hearts out)
"Should be" isn't "Is" -Jay
Message 23 of 25
(987 Views)
Here is a different solution that preserves the tcp-ip session between TestStand steps.
Under Configure->Adapters->LabVIEW:
I prefer using TCP-IP palette VIs for telnet because it is faster than TCP-IP over VISA (though it could just be my implementation).
Message 24 of 25
(957 Views)
Nice,  remember to call through the project context to avoid proxy caller namespace gotchas.
Message 25 of 25
(901 Views)
