TDMS files
Hello, I want to log data into a TDMS file every time I click a button, but the file is being created multiple times.
Thank you,
Message 1 of 14
(684 Views)
Hi KS200,
Because that's what you do in your VI: create a new TDMS file using the timestamp in the filename…
When you want to log into one (1) file then you should create the file once before the loop!
Message 2 of 14
(679 Views)
Thank you. If I want to create a new file each time I click a button, how do I do that? Because when I try to create it before the loop, only one file is created. If I click the button again, no other file is created.
Message 3 of 14
(676 Views)
Hi KS200,
Then you create a new file when you click the button (inside a case structure).
Hint: Use a latching button on your front panel…
Message 4 of 14
(661 Views)
You can use Boolean Crossing PtByPt VI to detect the rising edge of your shared variable signal.
Control Lead | Intelline Inc
Message 5 of 14
(641 Views)
Hello, I tried both solutions and I can create a file each time I click the button, but the file only contains one value each time. How can I fix that? Thank you.
Message 6 of 14
(566 Views)
Hi KS,
Write more data/samples to the file!
Maybe the more reasonable help would be to analyze your code. Unfortunately you don't show it to us…
Message 7 of 14
(553 Views)
Hello, I am using this VI, thank you
Message 8 of 14
(548 Views)
Hi KS,
please downconvert your VI and attach again.
(Many of use don't use the latest LabVIEW versions due to license issues, so you should downconvert to LV2021 or older. I prefer LV2019.)
Message 9 of 14
(544 Views)
Hello, I am going to look into how I can do that. In the meantime, here is an image of the VI. Thank you.
Message 10 of 14
(541 Views)
