03-14-2011 08:40 PM
Dear LV'ers
after reading lots of TDMS related posts, i have gained basic knowledge on using it (atleast). but my recent project application was a bit complex design and need to manage enormous data. with a few knowleldge on TDMS function, I still cannot figure out how to start with my design. any help from you guys are greatly appreciated.
In our design, we prioritize budget cost and independencies (no DIADEM, no other database software), that is why we really need to stick in using TDMS. here is the sample data management grouping we want.
each device will have different group name via parameter.. and each parameter will have sorted data via date... if possible, (if only), we want to retrieve data by its time duration (i.e. power data of device #1 from 10:00am to 4:00 pm of january 2)...
do we need to upgrade our LV software for datafinder function?
each TDMS files will sort via month.. (i.e. January.tdms, february.tdms, march.tdms and so on)...
can someone teach me how to do this design? or provide simple coding diagram on sorting data via parameter and date?
million thanks for any help!
03-15-2011 01:22 AM
Hi ivelson,
Seems the timestamp information is important in your application. You need to know each data values acquisition time, right? Otherwise, how you can retrieve data like from 10:00 to 4:00? This has a problem here, in TDMS file, it cannot record the time automatically. There are 2 kind of cases:
03-16-2011 08:13 PM
In my application, i have several machines and each machine have each parameters i need to be record (store / save). Based on your fact that TDMS has a limited layers, i think that my design layer was not applicable. but i think i can still do it by putting the timestamp in separate channel.
by the way, in item #1, how can i set the start time and time interval in the TDMS properties for data retrieval? for example, i provide a code below getting 10 data samples each second. i used the separate channel for time and device parameters. but i dont know how to recall the data for specific time (i.e. getting data from 8:51:52 to 8:51:56).
03-17-2011 12:32 AM
Hi ivelson,
For item #1, you can record the start timetamp and the time interval as 2 properties for the group. In your attached example, since the time interval is always a constant, you can calculate that from 8:51:51 to 8:51:56 data values positions are from the 2nd (if start from 0) to 7th, so you can wire 2 to the terminal "index" and wire 6 to the terminal "count" of TDMS Read when you reading the data values.
