TDMS location
I am trying to save a TDMS file using a Crio on a lab view software. The code runs successfully but i am not able to find the TDMS document on my computer? any suggestions?
Please find the attached blocked diagram.
Message 1 of 14
(3,928 Views)
That is because a cRIO is NOT part of your computer.  You have to treat it as another computer.  You need to set up a network communication between your cRIO and your computer so that the cRIO sends your computer the data and then your computer logs the data.  I highly recommend Network Streams for this.
GCentral
Message 2 of 14
(3,922 Views)
Thanks for the suggestion, actually I am new to this and have been using from 3 days, if possible could you please explain the steps a bit more? Thanks
Message 3 of 14
(3,886 Views)
NI LabVIEW for CompactRIO Developer's Guide
GCentral
Message 4 of 14
(3,882 Views)
Hi, if i connect a USB to Crio will I be able to retrieve the file then?
Message 5 of 14
(3,875 Views)
That will work as well.  It should show up as /U
GCentral
Message 6 of 14
(3,865 Views)
Tried that, still the file does not show up.
Message 7 of 14
(3,861 Views)
So what is your file path?
Have you tried to browse the cRIO folders?
How do you know it is not logging to a file on the cRIO?
Message 8 of 14
(3,847 Views)
I have tried plugging in the USB to Crio which shows up as drive U and I tried to save the TDMS to the file path as:  /U/TDMS/tdms
When I start looking for a file I can't find it there.
Message 9 of 14
(3,844 Views)
And what does you error cluster on the TDMS open say?
Message 10 of 14
(3,833 Views)
