TIMING ERROR IN DAQmx while using LINX
I would like to fix an error in my code.
I have included the screenshots of the error and the code in the attached folder.
The error message is related to the DAQmx timing which shows as:-
"Property Node (arg 2) in VISA Configure Serial Port (Instr).vi->LMH-LINX.lvlib:Device.lvlib:Serial Open.vi->LMH-LINX.lvlib:Device.lvlib:Initialize Device.vi->LMH-LINX.lvlib:Initialize.vi->LMH-LINX.lvlib:Open Serial.vi->MAIN-TEST FFT _8 x8_sensors.vi"
Please have a look and let me know your suggestions.
Arun
(525 Views)
Arun
The text of the error should tell you more about what happened.  I believe this is because a parameter that you specified for the serial open is inappropriate.
Bill
CLD
(Mid-Level minion.)
(480 Views)
Thanks for your reply. I tried to give higher values of the baud rate to check this to the serial open. But the same error is showing. I am attaching the screenshots of the error.
(457 Views)
Also, it is mentioned that "By default, LINX establishes communication using a baud rate of 9600 and then negotiates for the remote LINX device's maximum supported baud rate and re-establishes communication at that maximum rate."
(455 Views)
