Table Control Insert Data to Column 2
Hi Experts,
I have a table control. I created a local variable for the table control and I input data A to column 1 of the table. No problem. Easy.
Now question is, I have data B which I want to input to column 2 of the same table control. How do I do that ?
Merci amigo Smiley Wink
(3,264 Views)
You can add and replace.
Check the vi I included.
Koen
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(3,255 Views)
Hmm I still cannot get it to work.
I have two arrays. First array I want to put into Column 1 of table. Second array I want to put into Column 2 of table.
Please see attach photo.
(3,233 Views)
Accepted by pokerprof
Build Array, but do it with 1-D arrays.
(3,224 Views)
Ravens,
You made it seem so simple ! Thanks and it works now. I do not why did I miss that completely.
1D array input into Build Array to get 2D array of 2 columns.
(3,219 Views)
