Table control in labview
Hello everyone, could someonehelp me? I need help about table control and using data from table. Here is my vi, and i want to know how to use data from table in vi. I need to make some calculations with every value in table colum.
Message 1 of 10
(7,825 Views)
it is a 2D string array,manipulate data using the ARRAY PALETTE , loops and string conversions.
Message 2 of 10
(7,809 Views)
Any example??
Message 3 of 10
(7,797 Views)
@Nenoo wrote:
Any example??
not knowing what exactly you need, there are many examples.....try  "2D array" in the forum search  Smiley Wink
there should be something close to what you need, try it....and get back to us with a VI and any problems you have encountered with it.
Message 4 of 10
(7,775 Views)
What are you trying to do with the data?  If you are doing calculations, you will first need to convert from a 2D Array of strings into a 2D Array of numerics, most likely DBL.  You can do all kinds of fun stuff from there.
GCentral
Message 5 of 10
(7,760 Views)
@Nenoo wrote:
... how to use data from table in vi. I need to make some calculations with every value in table colum.
you are building your table as an indicator...couldn't you just wire directly the data directly into your calculations or make references to them from your sub.vi?
Message 6 of 10
(7,757 Views)
I can connect it directly, but i need to know how to take value from exact colum and make calculations with it(average value from all colums, devation and same...).
Message 7 of 10
(7,718 Views)
Hi Nenoo,
to "take values from table" you need to index array elements. Usually IndexArray is the function you need.
(Or autoindexing in a loop, depending on your task which isn't defined very well until now.)
This is pretty basic LabVIEW knowledge so I advise you to take the free online courses offered by NI!
Message 8 of 10
(7,714 Views)
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
GCentral
Message 9 of 10
(7,703 Views)
here's one part (average) for you....
Message 10 of 10
(7,684 Views)
