Tektronix 3054B Screenshot
I tried the same and getting timeout error.
I couldn't find any help for now in TEK site also.
Is there any update or solution for this issue.Please find the attached image of NI SPY.
I tried with some delay of 10 seconds after starting the hard-copy.
The problem is that i don't get the image from the GPIB using the "Read to File" function except for the timeout.
TEKTRONIX,TDS 3054B,0,CF:91.1CT FV:v3.26 TDS3GV:v1.00 TDS3FFT:v1.00 TDS3TRG:v1.00
Any suggestion or help is greatly appreciated. Thanks in Advance.
Davidson
Message 11 of 33
(1,591 Views)
Hi Davidson D,
What version of LabVIEW are you using and what version of the Tek 3054B are you using?
Joe Daily
may the G be with you ....
Message 12 of 33
(1,559 Views)
Dear Joe,
I use LabVIEW 8.6.1f version.
And TEKTRONIX,TDS 3054B,0,CF:91.1CT FV:v3.26 TDS3GV:v1.00 TDS3FFT:v1.00 TDS3TRG:v1.00
Davidson
Message 13 of 33
(1,543 Views)
Hi Davidson,
Were did you get the instrument driver?
Joe Daily
Message 14 of 33
(1,538 Views)
I hope the driver was downloaded from NI site. Its "tkds30xx.llb".
Actually this driver didn't have the screenshot options. So i was using the commands in manual "TDS30xx User Manual.pdf" and created a VI for the hardcopy function by sending the commands i highlighted in the SPY.
Davidson
Message 15 of 33
(1,530 Views)
Instead of doing a Read To File, try doing a normal VISA Read and set the VISA Timeout to a higher value.
You could also just save the LabVIEW image of your acquisition. That way, you do not transfer the same data twice.
Message 16 of 33
(1,522 Views)
Dear Joe,
Also i installed the latest driver "Tektronix TDS 3000 Series" - Project style from IDNET. It do not have Hardcopy functionality in it 😞
Davidson
Message 17 of 33
(1,520 Views)
@Dennis,
I will try this with the instrument and update what happens with the normal VISA read.
We are using the "save LabVIEW image" method temporarily.
Davidson
Message 18 of 33
(1,515 Views)
@Dennis,
VISA Read is also getting timedout.
Does anyone have the working version of this VI for screenshot?
Davidson
Message 19 of 33
(1,470 Views)
I got it working.
It was my mistake of sending the HardCopy start command incorrect.
I was sending HARDCopy:STARt instead of HARDCopy START
Smiley Mad I should have a lens to verify the commands that are sent to the scope.
Davidson
Message 20 of 33
(1,431 Views)
