Tensorflow Python Node breaks after weights load
Hello everyone,
I'm trying to run python node in LabView, but script return error 1672.
With script everything ok, but LabView have some problems.
Message 1 of 11
(2,425 Views)
Hello, NoKot333. Do you use any Numpy functions?
Message 2 of 11
(2,378 Views)
What is your LabVIEW version?
Message 3 of 11
(2,371 Views)
Message 4 of 11
(2,359 Views)
Accepted by NoKot333
I can confirm, I have seen error 1672 when returning a numpy array which is generated by the python script
in the following, I write a 2d buffer to the python node, extract the first column of this 2d buffer, convert this column vector to a numpy array and return as 1d array of doubles "y".
import numpy as np
def return_cm(data):
    y = data[:, 0]
    X = data[:, 1:]
    y = np.array(y)
    return y
the length of the y-vector can be manipulated by choosing a different number of rows, in the following screenshot 1000:
Error 1672 does halt the .vi, when the numbers of rows in this vector is bigger ~ 10.000 , but will work corretly if less e.g. 1000
Message 5 of 11
(2,345 Views)
There are some Numpy functions, which are not supported by LabVIEW.
Message 6 of 11
(2,325 Views)
Hello again. Can you send me kwhFinal.h5 for testing code on my PC?
Message 7 of 11
(2,316 Views)
Yes
Message 8 of 11
(2,282 Views)
21.0.1 (64-bit)
Message 9 of 11
(2,281 Views)
