Testo 350 M/XL control unit - Testo 454
Hello there,
I'm trying to connect the Testo 350 M/XL control unit - Testo 454 with LabVIEW.
I've got a toolbox from Testo, but I have no idea how to connect these two.
I think I need to change some settings from the control unit for the communication, but I can't find anything online how this is possible.
Anyone who has some experience with this?
Thanks.
Joris.
Message 1 of 9
(4,613 Views)
I found their manual online on their website.
The unit apparently has RS232 and their own proprietary data bus.
Read the manual that comes with their software which apparently is based on .NET Framework
Message 2 of 9
(4,607 Views)
Hello Joris,
What have you already tried?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 3 of 9
(4,556 Views)
I got the toolbox for testo 350 from testo.
But when I open the vi, I got an error for a file that could load, so you can't run the vi.
Another problem is that I can't get the control unit (testo 350 M/XL-454) in remote.
Anyone that knows how this is possible ?
Regards.
Joris
Message 4 of 9
(4,550 Views)
Hello Joris,
- From where did you download the toolbox?
Is it publically available?
- Which error did you get exactly?
Kind Regards,
Message 5 of 9
(4,544 Views)
I've got the toolbox from Testo itself.
The error has something to do with Tcddka.Itcddk
As solution I found on a thread you've got to cut and paste it again, but that doesn't solve the error for me.
Message 6 of 9
(4,532 Views)
Hello Joris,
Thanks for the extra information, but I will need the exact error to be able to help you search for the solution.
Otherwise we are searching a needle in a haystack. (a smaller one, but still a haystack)
Kind Regards,
Message 7 of 9
(4,526 Views)
I have no idea what changed, but the error disappeared.
I still have a little question about de testo itself.
Is it necessary to change settings to be able to enable remote control?
greets
Joris
Message 8 of 9
(4,504 Views)
Hello Joris,
Do you mean with "remote control" communication over RS232 or their own proprietary data bus.
If you need to change settings, should be mentioned in their manual.
Which manual did you use?
Kind Regards,
Message 9 of 9
(4,496 Views)
