Text property: Interpret As Unicode
Have you had trouble getting the "Interpret As Unicode" property to work consistently?  It always seemed buggy to me, but this morning I discovered that its not a bug, it's a feature (really!).  It turns out that it's like font properties in that it applies to selected text; if no text is selected, changing "Interpret As Unicode" has no effect.  To send new text in a particular format, do this:
To change the format of all existing text, do this:
Message 1 of 10
(3,501 Views)
You didn't know this tool?
LabVIEW Unicode Programming Tools
George Zou
Message 2 of 10
(3,461 Views)
Message 3 of 10
(3,398 Views)
paul, why is that one  property node in your snippet  yellow and the other two are brown?
I can't figure out how to use your snippet directly, so I tried to reproduce using the property nodes from the NI unicode tools:
Message 4 of 10
(3,387 Views)
The brown nodes are for internal NI use only (super secret scripting).
There's also blue (scripting) and red (obsolete) nodes.
Message 5 of 10
(3,377 Views)
The node is brown because the property "Interpret As Unicode" is designated private.  Ordinarily I try to avoid using private properties, but since NI uses this one in an addon toolkit, I feel OK about it.
The "Interpret As Unicode" is definitely changeable back to False.  Note however that setting the "Force Unicode Input" property to True changes "Interpret As Unicode" to True.  When "Force Unicode Input" is true, when you're typing text into the string, it converts it to Unicode.
To use my snippet with a string control, get the Text reference from a string property node.
Message 6 of 10
(3,346 Views)
yes, I made a copy and paste error in my snippet's comment ....
I want to write "you can go back to the previous state" 😐
thanks!
Message 7 of 10
(3,328 Views)
hm ... 🤔
Message 8 of 10
(3,314 Views)
Where can I get a Text's "Interpret As Unicode" property node, i.e. not String's "Text.Interpret As Unicode"? I have not found one in ni_lib_unicode-2.0.1.6.vip or LV_Unicode-115-lv2009 (no password).zip
Message 9 of 10
(1,710 Views)
Here
Message 10 of 10
(1,703 Views)
