10-02-2024 12:33 PM
I just build an rt application and there is something wrong with the text ring indicator from which I retrieve values.
Do text rings hold no value in a build rt application? What is the replacement?
10-02-2024 03:10 PM - edited 10-02-2024 03:11 PM
Hi Quiztus,
What is wrong?
Which error numbers do you get?
How does the code look like?
Using property nodes on headless RT targets might become tricky…
Is your RT target headless?
Use any kind of file you like to use to store parameters…
(Or exchange data with your GUI application running on the host.)
