Timebase
I am using NI 6025E DAQ card. Understand that the internal timebase is either 20MHz or 100KHz. May I know how I can select which timebase to use. Thanks.
(2,392 Views)
You may have to route the signal using the DAQmx Connect Terminals.vi (be sure to disconnect the signal after use).  For this, you will have to look at the Device Routes tab of your device in Measurement and Automation to see how the 100 kHz or 20MHz timebase can be routed.  See more information on this in "Developer Zone Tutorial: Timing and Synchronization Features of NI-DAQmx"  http://zone.ni.com/devzone/cda/tut/p/id/4322
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(2,385 Views)
Thanks for the advice.
(2,376 Views)
