Timing runs at 1 sample per second with simulated DAQ, but runs slower when connected.
I guess I need to see my laptop:D
I'm looking for the Task Configuration BD as an image.
"Should be" isn't "Is" -Jay
Message 11 of 25
(678 Views)
Hoping this is what you're after.
Message 12 of 25
(676 Views)
OK,
Time to show you how a pro does it
With a well commented BD and developer comments.  Took me 15 minutes.  The Task timing is assumed to be single sample on demand.
Developed in LabVIEW 2023 not backsaved
Message 13 of 25
(655 Views)
@JÞB wrote:
OK,
When I use a file dialog to populate a TDMS path I get the following error:
If I use a filepath, I get -201309
Using the highlight execution, the error occurs in the DAQ read, and it appears that both reads get the same channel for some reason.
No modification to the posted VI so not sure what's going on?
Message 14 of 25
(641 Views)
Hi LVIEWPQ,
Use two TDMS files for two DAQmx tasks: each task wants to have exclusive access to its TDMS file…
Message 15 of 25
(638 Views)
@GerdW wrote:
Hi LVIEWPQ,
Even with 2 different logfiles, I get Error 201309.
Followed : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DmwnCAC&l=en-GB which hasn't resolved the issue.
Message 16 of 25
(644 Views)
Hi LVIEWPQ,
Error -201309: "Unable to write to disk. Ensure that the file is accessible."
Which filepaths do you use?
(On which target is your VI executed?)
Message 17 of 25
(641 Views)
I have tried
"C:\Users\lharris\Desktop\Pressure logfile.tdms"
"C:\Users\lharris\Desktop\Temperature logfile.tdms"
@GerdW wrote:
Hi LVIEWPQ,
"C:\Users\lharris\Desktop\Plogfile.tdms"
"C:\Users\lharris\Desktop\Tlogfile.tdms"
Message 18 of 25
(630 Views)
@GerdW wrote:
Hi LVIEWPQ,
I have a sneaky suspicion that the Task configurations are not 1 sample on demand.
Show a screenshot of the DAQmx Wizard.  Just right-click the Task constants and show the configuration page.
Message 19 of 25
(618 Views)
@JÞB wrote:
@GerdW wrote:
Hi LVIEWPQ,
Everything appears to be set up correctly?
Message 20 of 25
(570 Views)
