To delete a non repeated element from Array.
Check this
Message 11 of 18
(1,023 Views)
Actually I need the non repeated elements to be deleted and the repeated elements to be printed once.
Message 12 of 18
(980 Views)
Hi Hemanth,
I'm sorry, I implemented it in the opposite direction…
Adapt as needed - or use the Map approach also shown in this thread!
Message 13 of 18
(973 Views)
Here are a couple different ways.
Message 14 of 18
(960 Views)
Can u help me out i can't figure it out....
Message 15 of 18
(934 Views)
Hi Hemanth,
Who is "u" and why can't you use one of the suggested solutions?
Message 16 of 18
(924 Views)
Accepted by topic author stark8
Have you tried my solution?
Is your expected output matches with the below results
Message 17 of 18
(913 Views)
I would probably use a map as follows (Note that the input does not need to be sorted):
Message 18 of 18
(895 Views)
