Transfer data from RT to FPGA
I need to send a clock speed (declared in the RT VI) to the FPGA, but only once, so I'm trying not to use a DMA FIFO that would be read more than once.
I already tried to use global and shared variables but it didn't worked.
Does anyone know how I could do that ?
(589 Views)
Hi Bivrox,
There are several options to exchange data between FPGA  and RT host, and they are all explained in example VIs/projects coming with LabVIEW.
Globals or SharedVariables don't belong to that list of options!
Have you tried to use a simple control in your FPGA VI?
(583 Views)
I can't use simple control because of the hierarchy i'm having in the project (the FPGA vi isn't directly called in the RT there are lot of VI called before it).
Where could I find the examples given by Labview ?
Thanks for your help !
(577 Views)
Hi Bivrox,
I don't understand your problem…
Either example finder or in the "File->New…" dialog…
(570 Views)
I need to send the "FPGA Frequency" (in my RT VI) to my FPGA VI, this data will never change once the program is running, it's just to adjust the FPGA frequency by hand.
Here is my FPGA VI using it:
(I can't publish my entire project but you can see the FPGA Frequency being collected then used to time the FPGA loop)
(562 Views)
Hi Bivrox,
  • Usually you start the FPGA VI when opening the FPGA VI reference (or even upon startup of your RT target (cRIO?): when you write to this control in your RT host "much" later after the start of the FPGA VI then the FPGA will never use your new frequency value because it uses the value from this control read upon start before the loop. That's called a race condition…
  • How do you transfer the value into this global variable of your FPGA target? Why don't you use a control even though you use an indicator in the FPGA???
I still don't understand your problem and I also understand your code constructs. (Maybe because you only show very small part of the code.)
(541 Views)
Understanding Communication Options Between the Windows HMI, RT Processor, and FPGA
For your use case, you can look at the options for Tag
Control Lead | Intelline Inc
(462 Views)
