Transformation of plot's axes
Hello all,
    I am plotting Weibull data, and am attempting to use the original Weibull graph axes.  In a Weibull plot, the percentage of items still functional at a given time t, or the reliability R(t), is plotted versus that time.  Here is the problem:  the abscissa is the natural log of time, while the ordinate is (get ready) the natural log of the natural log of the reciprocal of item reliability at a given time, i.e.  ln(ln(1/R(t))).  I understand how to get a log axis, but that clearly is insufficient for the ordinate.  Is there any LabVIEW functionality that allows axis transformation, or must I content myself with merely performing the transformation on the data itself, rather than the axis scale?  (We are currently doing this, but it removes the sensible reading the transformations provide.)
Thanks for any advice,
Nathan
(2,705 Views)
You need to transform the data yourself.
(There are several ideas in the ideas exchange that try to address this limitation.)
(2,701 Views)
Is there any way then to manually construct the axis scale?  Spacing, values, etc.  Ideally it would look something like the image here:  http://images.books24x7.com/bookimages/id_9017/0315.jpg
(2,679 Views)
Accepted by reformedView
For the most general case, you would need to do everything yourself using a 2D picture indicator.
(Open the example finder and look at the example "XY Multiplit Graph" for some ideas).
(2,673 Views)
That's what I was gearing up for.  Thanks for the confirmation.
(2,666 Views)
