Transforming a Sine wave in a rectified sine wave
Hi there!
I am trying to make a VI where I transform a plain sine wave into a rectified one. Can anyone tell me why this is not working?
Message 1 of 8
(5,936 Views)
Accepted by icamaster
You only have a single value coming out of your "less than zero?" node. That means it is making a single decision, so I think it looks at the average of the Y array and determines if it's less than zero. You really want to go on an element by element basis. So use "get waveform components" to get the Y array, put it into a For Loop, and try your logic again. Then  "build waveform" using your previous waveform and only bundling in the new Y array.
Message 2 of 8
(5,931 Views)
I think this will also do what you want:
Message 3 of 8
(5,927 Views)
What's wrong with the absolute value function?
Message 4 of 8
(5,906 Views)
Yes, it was so obvious. This did the trick, thank you!
Message 5 of 8
(5,902 Views)
Hopefully you are not really going to do whatever you marked as solution above :o.
Message 6 of 8
(5,894 Views)
Your solution was fine for Full-Wave but I also want a Half-Wave, which takes only positive values.
Message 7 of 8
(5,884 Views)
That's the first time you mention half-wave. How are we supposed to guess that?
But even for half-wave you don't need a FOR loop.
Message 8 of 8
(5,869 Views)
