Translating a string into a number (Homework Help)
Hello Everyone,
Just looking to be pointed in the right direction, not looking for the specific answer as I am still trying to learn LV.
I'm still pretty new to using LV and was wondering if anyone could help me when it comes to converting a string into a number. What I want to do is ultimately "decode" a word and translate it into a number.
It would follow this code for the translation:
1=a, 2=b, 3=c, 4=d, 5=e, 6 =f, 7=g, 8=h, 9=i, 0=g and -1 otherwise.
Example would be the number 365 is written as cfe.
TIA!!
(110 Views)
This smells like homework. What have you tried?
Once you describe what you tried and where you got stuck and show us you attempt, we'd be happy to comment.
(110 Views)
Hi yes this is a homework problem! I am not looking for the answering just rather trying to figure out how to go about this. I used 2 array constants where I dragged the string and numbers into them. Then for the string input for the user I connected it to a string length then connected it quotient and remainder to see if length mod 2 ==0.
Im now planning on using a for loop with a string subset where I will connect the user string input to it. This is as far as I have gotten
(104 Views)
You have a string (word), not an array of strings as input.
You can convert your string to a byte array and use it to index into a lookup table, (or suitable map), iterating over all characters of the input.
Your problem is actually not clear, especially the "-1 otherwise". For example if the word input is zzzzz, would the result be -1-1-1-1 or just -1?
How long can the word be?
Can you explain why 7 and 0 are both "g"?
(81 Views)
Assuming "0" is actually "j", here's a quick draft. See if you can figure it out.... 😄
(56 Views)
My bad, you are right it would just be -1.
0 should be j, I mistyped by accident.
(36 Views)
