Tunnelling Problem
Here is the .vi. Very much appreciate your help. Could you explain the new things you do to it. Thanks,
Nevica
Message 11 of 16
(780 Views)
I am using LV 2010. Please save it to previous version and send
Guru (CLA)
Message 12 of 16
(775 Views)
I also use LV2010. Maybe exchange the stacked sequency to a flattened one and have a look at the wiring; I am quite sure that you will immediately see some wires that you did not intend to be like that...
The upper box I was using was an error cluster constant, the other one is the "merge error.vi" you will find it in your functions palette.
Message 13 of 16
(766 Views)
A rather simple way to get rid of the sequence and avoid the multi connectors is to replace it with a For/While loop and Case structure connected to 'i'. Then you can send your error out to a shift register and use the same connection on all.
Even better is to change the case connection with a enum with a descriptive name, then each case will describe what it does.
Then you can bundle up the functionality in each case/sequence frame into a sub-vi of it's own and simply wire them together. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 16
(734 Views)
/Y
Kind of like a machine with... states???  Brilliant! Smiley Very Happy
Message 15 of 16
(727 Views)
😉 Sneak the idea onto them.
/Y
Qestit Systems
Message 16 of 16
(720 Views)
