Turn OFF LEDs in case structure
I was wondering if someone could help me solve a small issue in a test bench software I am trying to develop. I have attached a section of my code in which the problem is visible. I have a case structure that is triggered by a 'Push Button'. I want the TEST RUNNING LED to stay ON until the end of the execution of the case structure (True condition) and turn off once it is completed. But the LED fails to turn off and remains ON. Is there anything I can do in the False condition to turn the LED off when the code isn't running. Please note that to run the program you will need to 'Run Continuously'. I want the LED to turn off once the 'Result' is obtained so that the operator of the software can know he is free to run the next test. But now when the 'Start Test 2' is executed after 'Start Test', the LED remains ON.
It might be a simple solution which I may be unfamiliar with, but forgive me, I'm a new Labview user and I couldn't find a solution to this online.
Thank you.
DPac
Message 1 of 15
(7,606 Views)
Accepted by topic author DPac
Hi DPac,
simple solution as requested:
Message 2 of 15
(7,600 Views)
I can't see your code, but from what you explained, Property Node sounds like solution to your problem. Just create a property node for LED and make the value property flase outside of the case stucture.
Kudos are (always) welcome for the good post. 🙂
Message 3 of 15
(7,595 Views)
GerdW has the solution you want.  But you really should not design VIs that have to use the Run Contiuously.  While loop with an Event Structure would serve you much better.
GCentral
Message 4 of 15
(7,585 Views)
Hi GerdW,
I'll try out what you have suggested and see if I can get it to work.
Cheers
DPac
Message 5 of 15
(7,556 Views)
Hi crossrulz,
Cheers for your suggestion mate, I'll change it to a while loop.
DPac
Message 6 of 15
(7,551 Views)
Thanks GerdW, your solution worked!
Message 7 of 15
(7,550 Views)
hello can u send me the VI how to turn off the LED when it is in false case and turn on when it is in true case. thankyou. your help are much appreciated
Message 8 of 15
(7,177 Views)
Seems I accidently deleted that picture…
The test code is also located inside the TRUE case…
Message 9 of 15
(7,173 Views)
THANKS. youre awesome.
Message 10 of 15
(7,140 Views)
