09-04-2007 04:42 AM
I have downloaded the example USB-6501 Interactive Control but I can’t use it. I plug in my computer with the adaptor box and I check the 25 pins of the tester. With a multimeter I can calibrate all the pins and I observe that some of them have 5volts and the others have 0, high and low level, as it is supposed to be.
However, when I run the program and I try to change from High to Low it appears this error:
Error -200220 occurred at an unidentified location
Possible reason(s):
Device identifier is invalid.
If I change the name I have a different error:
Error -200558 occurred at an unidentified location
Possible reason(s):
One task cannot contain multiple independent devices.
Create one task for each independent device.
I don’t know if I’m introducing bad the name or what can be wrong. I would thank if someone could help me.
Vicente
09-05-2007 04:38 AM
