USB High Speed data transfer from a FT2232H
I want to transfer data at a rate of about 100 Mbit/s or 12 MByte/s from a user board to Labview. Is this possible?
Continuous data stream.
I am new to lab view but I have read that lab view can interface to user hardware. I probably need the dll from FTDI for that. They have even examples, but they are for lab view 7.1, so not sure also here.
Thanks in advance...
Mark
(2,073 Views)
Accepted by 11MW99
I think a colleague of mine is using these chips to do insanely-fast VISA transfers with LabVIEW.  If you do a Web serach for FTDI LabVIEW, you will find a 2019 NI White Paper saying that you can get drivers compatible with LabVIEW 7.1 and later.  Give it a try.
(2,031 Views)
Thanks Bob,
I will look for this paper.
I have this driver and some sample VIs from FTDI.
I will start with them once I have lab view installed.
Mark
(2,027 Views)
