12-19-2023 11:46 PM
I am on Windows 8.1 and I have LabVIEW 2020 SP1 installed in my PC but when I try to interface Keithley 2260B-250-9 with LabVIEW, I am unable to find and update the specific USB driver for the same. Help me resolve the mentioned issue.
12-20-2023 01:21 AM
Hi Mahmudul,
@MahmudulHasan123 wrote:
when I try to interface Keithley 2260B-250-9 … I am unable to find and update the specific USB driver for the same.
Isn't this a problem you need to discuss with Keithley?
They need to provide the "USB driver" for their device!
12-20-2023 02:23 AM - edited 12-20-2023 02:24 AM
Try to go to Google and enter "Keithley 2260"!
The first non-sponsored link is the below page. The sponsored links are also from Tektronix-Keithley but less specific to your device.
https://www.tek.com/de/products/keithley/dc-power-supplies/2260b-series and then from there go to the Downloads section. I would suppose that you need to go with the Keithley I/O Layer version C10 driver.
12-20-2023 03:28 PM
While not technically helping with your question as asked, I would VERY strongly recommend using the Ethernet port on that device instead of USB. I have found that once you get over the initial hurdle of a slightly harder setup, the Ethernet connection is 10 times more reliable than the USB connection is.
It would also have the side benefit of not needing a driver at all...
