07-02-2015 08:52 PM
Following is anouced;
After tuning the RF front-ends, each local oscillator may have a random phase offset due to the dividers in the VCO/PLL chains. This offset will remain constant after the device has been initialized, and will remain constant until the device is closed or re-tuned.
However,
I found the phase offset did not remain constant for some USRP N210 with WBX in for USRP N2x0 receivers synchronized system for 20 minutes.
I am trying to build phase synchronized measurement system using USRP N200 x 2, N210 x 2 OCTOCLOCK .
ch1 and ch2 is connected with MIMO cable
ch3 and ch4 is connected with MIMO cable
ch2 and ch4 is connected OCTCLOCK wiith 10MHz and PPS.
All inputs were coupled to SG not sincronized output.
attached screen shot shows the results observed for 200 minutes. .
Right end Plot shows drift of phase offset during 200 minutes ; white line is ch2-ch1 , red line is ch3-ch1, green line is ch4-ch1.
It seems each MIMO pair has kept the same phase offset but diffreent MIMO pairs.
Is this expected results?
Below is the configulation in LabVIEW Block diagram.
03-15-2016 10:07 PM
I have tried following example, and found my USPR N210 WBX pahse offset remain constant.
My vi may be something wrong.
Sorry for posting the wrong infromation because of my misunderstanding.
After resolving my Vi mistakes, I will show them.
03-16-2016 09:19 PM
Here is the results of 4ch phase measurement for 1000 seconds.
ch reference Clock TX/RX RX
1ch MIMO SG E100
2ch Ext octaclock SG
3ch MIMO SG E100
4ch Extr octaclock SG
1ch and 3ch are connected E100 output which frequency 915. 18 MHz
1ch , 2ch , 3ch and 4ch are connetcted SG which frequency 915.66MHz
All phase are stable arround +/- 2 degree.
Vi will be attached soon.
03-16-2016 09:33 PM
Here is sources.
03-16-2016 10:31 PM
Thanks chiyofivetimes!
04-07-2016 07:43 PM
I found unstable phenomena occurs in the condtion that NI_USPR set time.vi applying timestamp "Now" .
04-07-2016 07:51 PM
Here is a unstable phenomena.
As my first message, MIMO pair ch1 and ch2 are stable and ch3 and ch4 are drifting.
And, 3-1 dphase cal and 4-1 dphase cal are changing around 100deg periodically.
Could somebody explain the reason?
