Unable to seperate serial data from different channels
Hi Singh,
@Deepti_Singh wrote:
Can you please tell me what different I did.I tried the same example.
I didn't save that VI. I guess it's a nice exercise for you to recreate that code using just 4 basic LabVIEW functions, a loop, and some constants of the right datatype…
You did different:
  • You  convert to an array of DBL with the SpreadsheetStringToArray function. I created an array of strings as can be seen in my image.
  • You used a different array function than can be seen in my image.
  • The content of the FOR loop looks different to my image.
  • The output array is of DBL type while my image shows an integer array. (All the values in that string seem to be integers…)
Message 11 of 11
(231 Views)
