Using LabVIEW 64 bit and 32 bit both on the same laptop
Hello, I am trying to activate my LabVIEW 2024 32bit and got this message ( there is no license associated with your NI user account. you can try again or choose another method to activate.) I already have working licensed LabVIEW 2024 64bit working on my laptop, but I need to activate the 32bit to be able to use some libraries that need 32bit version to work. Thank you. Capture.PNG
(488 Views)
Just change to Enter key instead.
Qestit Systems
Certified-LabVIEW-Developer
(478 Views)
serial number or activation code ?
(465 Views)
Run the NI license manager app and activate from there. That worked for me when this happened. I think a PC restart also helped once.
Certified LabVIEW Architect
(394 Views)
Thank you.
(339 Views)
