Using the DAQ-9178 and 9205 Voltage Module, how do I build a 16 Channel Voltmeter with a range of 0--50Vdc?
I have already built an 8 channel 10:1 voltage divider using 1% resistors.  My problem is there is a lot of AC noise on the DC signal and the voltages don't match my Fluke DVM which is sitting beside.
(2,515 Views)
Accepted by Mmattlabrat
A little more info... Only Channels one and two have signal going to them.  Ch1, (a0), is connected to a 9volt battery, and ch2, (a1), is connected to a variable bench supply set for 17Vdc.
The DVM is rock steady, however the LabVIEW indicators show what I assume is a product of the AC noise.
Any help would be appreciated 🙂
Thanks so much
-Matt
(2,504 Views)
You've marked the thread as solved so can we assume the problem is now okay?
(2,476 Views)
Yes Thank You!
(2,471 Views)
