VI Fails to send queue elements
I am trying to use a queue to send data from my pulse train subVI to my main VI.
After my pulse train completes, I send a TRUE boolean via the 'Enqueue element' which goes to the 'Obtain Queue' and then to the Dequeue Element to acquire and log data.
I am not sure why the data is only sent the first time, and not consequentially.
I've tried the same with the Notifier to no awail. I am not sure if this is an issue in my SubVI or my main VI.
I am not sure if this is correct? Do I need to release the reference or something?
Thanks!
Message 1 of 8
(3,686 Views)
here is the pulse train. I would have figured that if I have this in the 'Cycle' message case, if I call it again, which it does successfully, I would be sending another TRUE boolean to my main VI, but it doesnt..
Message 2 of 8
(3,679 Views)
Your Dequeue Element is only ran once.  That needs to be in a loop.
GCentral
Message 3 of 8
(3,668 Views)
Thanks - I tried that in a while loop, also tried probing the queue prior to it - would this probe list all of the elements queue up?
If so, the additional elements never enter the queue....
Message 4 of 8
(3,665 Views)
Probing the queue reference will not show the elements in the queue.
If you are sure you are not getting more elements in your queue, then it is a problem with your producer loop.  Are you sure that loop isn't waiting for a message in order to do something that would then add an element to your queue?
GCentral
Message 5 of 8
(3,648 Views)
I am sure it's not waiting for a message.
I created a message case solely to test the enqueue element function, probed the message queue, and see that the subVI is going through the various message cases.
How do I debug whether or not elements are being added to the queue?
Thank you
Message 6 of 8
(3,643 Views)
Breakpoints at the Enqueue Element is the simple way since the code will stop when it hits a breakpoint.  If it keeps stopping at the breakpoint, then you should be adding more elements to the queue.  Also make sure there are no errors happening.
GCentral
Message 7 of 8
(3,617 Views)
I hope this is just a gutted VI?  Because if you usually code with sequence structures and no dataflow with error wires, then I can't even guess what might be your problem.
Bill
CLD
(Mid-Level minion.)
Message 8 of 8
(3,583 Views)
