08-02-2023 12:23 PM
I've got a VI that I've made for users to open while running the main application to look at and modify data they've been taking. But I want them to still be able to interact with the Main.vi while it's running asynchronously. How does one achieve this using the VI Properties?
08-02-2023 12:39 PM
Not that I have an answer, but why does it need to be "through properties"?
08-02-2023 01:01 PM
The only guess I have given the very limited information presented is that you need to change your choice of Default/Floating/Modal under "Window Appearance". If one is Modal, or one is Floating but the other is not, you may run in to issues.
See the details here for differences between the 3 options:
08-02-2023 01:23 PM
This where the behaviors are changed, so I thought. Is there another location you are aware of?
08-02-2023 01:27 PM
The answer was Floating on Floating. Thank you.
