04-26-2011 08:56 AM
I was able to open the file I uploaded in LabVIEW 10.0f2. Which version of LabVIEW 10 do you have?
04-26-2011 08:58 AM - edited 04-26-2011 08:58 AM
By the way, you may want to review the Knowledge Base article on the Producer-Consumer architecture, which is what you seem to be trying to use.
04-26-2011 09:02 AM
Could one of your subVI's being causing the crash?
I was able to open the VI just fine in 10.0f2, but I had to tell it to ignore the half dozen or so missing subVI's.
04-26-2011 09:04 AM
I'm running labVIEW 10.0 Development system.
I just get a white faded out window with a prompt to close labview when I try to open the vi...
04-26-2011 09:08 AM
Would it help to upload the vi's that i call from the top-level vi?
04-26-2011 09:09 AM
If that's what's really causing the crash, then yes, it would help.
You may also wish to update your LabVIEW, since there has been a patch released for LabVIEW 10.
04-26-2011 09:14 AM
Ok thanks, I'm downloading the patch now as we speak, will upload the sub vi's i'm using...
04-26-2011 09:18 AM
Sub vi's called from top-level vi attached below.
I'd be grateful if you could have a look when you've time.
04-26-2011 09:20 AM
No problems opening all the VIs in 10.0f2.
04-26-2011 09:24 AM
Same here. I also went back to the originally posted VI, and had no problems opening that either in 10.0f2.
