VI stuck at Call by Reference
Accepted by MarkDK
It is not clear to me why you are using Call by Reference.  Why not make the VI reeentrant and do a simple call?  Note that if you call the VI from inside itself (a recursive call that takes advantage of reentrancy), that's perfectly fine ...
Message 11 of 13
(1,016 Views)
Thanks Bob_Schor!
Changed it to a simple call and it seems there is no longer any issues - why did this solve the problem?
Message 12 of 13
(974 Views)
I updated Cluster_logging.zip to Cluster_logging2.zip using Autotestware Cluster Toolkit 2.0.0.4.  Now works.  Easy, flexible.
Message 13 of 13
(839 Views)
