VISA blocks
i want to use pyvisa instead of visa blocks in labview, is it possible to do it??
(490 Views)
Hi Anup,
So you want to call a Python script (that uses pyvisa calls) from LabVIEW instead of VISA functions directly in LabVIEW?
Why?
(469 Views)
That's about as logical as wanting to go to the 100th level of a skyscraper, but not wanting to use the elevator but rather the fire escape stairs. Is your LabVIEW building in fire? 😁 Or is it about the physical exercise you want to have?
Rolf Kalbermatter
My Blog
(456 Views)
Just why?
Santhosh
Soliton Technologies
(423 Views)
I want to check protocols , like how it communicate with labview .
as there are limitations to check every protocol thats why
(377 Views)
I have no idea what that means. Can you be more specific what using pyvisa from LabVIEW would help you with that?
pyvisa is a somewhat roundabout way of implementing VISA for use under Python. As such it is just a limited reimplementation of VISA (if you use their native VISA layer instead of the NI-VISA interface in it) and as such offers no advantages for use in LabVIEW, compared to the native LabVIEW VISA interface. Rather the contrary is true, you add an additional complication of having to interface to Python from LabVIEW, to be able to use pyvisa. While that's possible, it for sure adds extra complexity, intermediate translation layers and much less interactive debug possibilities than the native interface.
Incidentally I just finished a reimplementation of a Python interface to a remote software (Thales) in LabVIEW. The manufacturer has a comprehensive Python interface for their system and their LabVIEW support consists of having an additional Python module that translates their class based Python driver into a function based one for use through the Python node. Cumbersome, tricky to get right as the various module paths need to fit exactly, a major pita when switching between 32-bit and 64-bit mode as the Python installation needs to be adapted too and the modules installed in the right environment. That the performance of all this certainly doesn't impress either, is a minor detail. I don't expect high speed from communicating with an instrument even if that is through TCP/IP.
Reimplementation of the whole Python driver in LabVIEW did cost a few days, using the native LabVIEW TCP nodes. But it now works independent of what bitness or even underlaying OS it runs on, doesn't need a Python installation alongside LabVIEW that is setup exactly right and is actually more responsive too.
Rolf Kalbermatter
My Blog
(370 Views)
Discussion is related to this thread
(360 Views)
