VIs immediately tagged dirty on open
If all I do is open a VI- I don't even click the mouse, change views or ANYTHING, it gets the asterisk in the title showing it has been changed.  But nothing has changed.
How do I stop this behavior which includes asking me if I want to save on close?
Message 1 of 16
(3,470 Views)
Do you have the "Seperate From Compiled" turned on for the VI?
GCentral
Message 2 of 16
(3,467 Views)
I've never set that property, so it is set to whatever is the default value.
Message 3 of 16
(3,464 Views)
Then that is likely your problem.  If something in a subVI changed, that would cause this VI to have to recompile, therefore causing a change in the file.  If you have the seperate from compiled turned on, then the compiled code is not saved with the source code and you will not need to resave just due to a subVI changing.
There is an option to have it on be default.  I highly recommend using that.
GCentral
Message 4 of 16
(3,458 Views)
I haven't changed anything in a sub-vi.  I start LabVIEW open a sub-vi and it is tagged dirty.
Message 5 of 16
(3,456 Views)
What does "List Unsaved Changes" say?
Message 6 of 16
(3,412 Views)
How to Check "List Unsaved changes"?
Message 7 of 16
(3,364 Views)
Hi PAnand,
close the subVI without saving it before. Then LabVIEW will ask you for saving with presenting a dialog where you can "check for unsaved changes"…
Message 8 of 16
(3,357 Views)
@GerdW wrote:
Hi PAnand,
Thanks Gerd I never noticed before.
Message 9 of 16
(3,351 Views)
Also in the VI Properties window is a "View Unsaved Changes" button.
GCentral
Message 10 of 16
(3,329 Views)
