Variable size array handling
Dear LabVIEW Gurus.
Here is the internal part of the loop. I get an array from the loop outside the case structure and manipulate the last array element.
The problem is that I don't know the array's size in advance.
Therefore, I don't get this element.
I could get this size from a loop outside the case structure, but I don't know how to use it.
I would appreciate any suggestions about this case
(287 Views)
Accepted by topic author Zoycha
Hi Zoycha,
There is an ArraySize function. And the last element has index "size-1"...
Or you use the DeleteFromArray function: read its help...
(You could even reverse the array order and index the first element: so many options!)
(282 Views)
Hello GerdW
Thank you very much for the assistance.
Now it works perfect.
(220 Views)
