Veristand
I am trying to log data continuously in NI Veristand. So i will be needing to disable the Data logging with Stimulus Profile Editor since I would use the Embedded Data Logger to log the data instead.
Is it possible to disable the Data logging with Stimulus Profile Editor when the stimulus profiles are running?
(2,602 Views)
Hello Lakshmi post your queries regarding NI Veristand in the specific NI Veristand forum you will get better response and try searching the question in that forum.
(2,591 Views)
If you don't have any logging configured for your stimulus profile, then no logging will take place for that stimulus profile. In that case there is nothing to disable.
Jarrod S.
(2,571 Views)
Can you please post link for veristand forum.
(964 Views)
Hi kishan,
See the forum tree in the upper left of the LabVIEW board and choose:
Discussion forums -> Additional NI product boards -> VeriStand…
(934 Views)
