11-15-2006 05:46 AM
11-16-2006 07:13 AM
11-16-2006 07:45 AM
11-16-2006 09:00 AM
07-15-2013 10:42 AM
Did you find a solution to this? We are having the same issue, and our Network admin is not too happy as well.
08-02-2013 08:22 AM
Greetings,
I am an admin and I can tell you I'm not happy about that at all. It should not be a default behavior. I don't know any admin that would want their network flooded with packets like that.
08-02-2013 01:13 PM
@cpcadmin wrote:
Greetings,
If the statement above is correct that the packet is only broadcast every few seconds this is hardly flooding th enetwork. Any Windows PC spews lots more junk than that. While I agree that there should be a way to disable the broadcast packets as an admin I would not be too bothered by a device sending a packet every few seconds. My PC sitting idle sent 181 packets in 11 seconds. Three or four UDP broadcasts added to this is certainly not that significant.
08-02-2013 03:31 PM
It is as exactly as you said. Every PC/device is sending unicasts and broadcasts. It's their combined numbers that can make it a problem. I'm disappointed when I see a device's default behavoir set to broadcast, I get more concerned the more devices I have on my LAN that act that way. IPv6 will help but we are not yet ready for that internally. I"m guessing most aren't either.
Nice tag BTW, One of my guilty pleasures.
08-02-2013 04:32 PM
Sailing or boating? I race sailboats on Lake Michigan. I crew for a 42' boat.
