May I recall you that to clear a graph you have to create a property node,
choose value and connect an 1D array with its first value to zero.
Then using a Select vi enables you to choose from clear or graph value.
Gérard
Gérard Férini
Switzerland
http://home.tiscalinet.ch/gferini/
remove -move to reply personally
"Greg McKaskle" wrote in message
news:xEmJc.43762$mY2.17348@fe1.texas.rr.com...
> > I went into the function pallette-->signal manipulation-->align and
> > resample
> > and found something that may be useful, but I'm not sure how to use
> > it. I guess I have to play around with it by trial and error. Was this
> > the VI seetting that you were referring t
o?
> The option I was talking about is for the entire VI. It resets the
> value of all indicators prior to running. The setting is located in the
> VI Properties dialog on the execution page I believe. In the end, there
> are multiple ways to get this to work, and if you want just a few
> indicators to be reset, you want to use locals or control methods, but
> th eVI Properties is a convenient way to get all indicators cleared at
once.
> Greg McKaskle
