Web Publishing Tool connect button unclickable/Greyed out
I'm trying to get the Labview Web Publishing tool to work for a VI. I have the web server enabled in the Tools - Options - "Web Server: Configuration" menu. I also have disabled the firewall. I can't find what is causing the problem. Attached is a picture of what I mean when I say I cannot click the Connect button.
(2,857 Views)
Accepted by weschiu88
Nevermind, I had to change Web Server: Configuration - HTTP Port from 80 to 82 and then it worked
(2,837 Views)
I had the same problem, how do you change the http port from 80 to 82?
(2,630 Views)
Hi Sanchez77,
Try going to Tools >> Options >> Web Server. There you should see HTTP Port. You can also select the Web Application Server to configure the Application Web Server port. What version of LabVIEW are you using?
Kaitlin N.
Applications Engineer
(2,620 Views)
