What GPIB drivers should I use for LabVIEW 2010?
Does anyone know?
Will NI 488.2 2024 Q1 work for me located here? https://www.ni.com/en/support/downloads/drivers/download.ni-visa.html#521671
Should I use NI VISA 5.4
Release Date Aug/05/2013
Thank you
(363 Views)
As per this article you will need the following compatible version of 488.2 and VISA drivers,
Santhosh
Soliton Technologies
(347 Views)
Something may be wrong with my drivers, but I have correct drivers for both NI 488.2 and NI-VISA as per your pictures
I have a different laptop with LabVIEW 8.5 on it, with different versions of NI 488.2 and NI-VISA. It works when I run a certain command, via GPIB Write function.
When I run the exact same command, with the same GPIB Address, and same GPIB cable, it does not work
Error 0 occurred at GPIB Write in Untitled 1
Possible reason(s):
LabVIEW: Error connecting to GPIB driver or device.
NI-488: Error connecting to driver or device.
VISA: (Hex 0x0) Operation completed successfully.
EDIT: When I run MAX, I am able to 'scan for instruments' and it is able to retrieve the *IDN? of the device.
But in my VI, I am not able to do the same with GPIB write and GPIB read.
In fact even using the built-in LabVIEW GPIB VI example it immediately gives the same error, but yet it works with NI-MAX?
(315 Views)
Everything works now after restarting my laptop. Thanks
(300 Views)
