What am I doing wrong when trying to calculate peak to peak of my wave form that I am reading?
@crash_override wrote:
 Is there a way to populate an array with 10 values divide by 10 and use that value and then clear the array for the next 10 samples?
You are way overthinking that. Why would you need to clear the array if you overwrite each element later anyway?
For a good introduction and alternatives, have a look at our old NI Week talk. I am discussion exactly this problem in part II on slides 12-14 and show alternatives and how they compare. So watch the video, download part II, look at the slides, and inspect the example. Good luck!
Message 11 of 21
(1,401 Views)
Is there a way to compute peak to peak voltage in labview built in? If not, how can I read the waveform and do it manually?
Message 12 of 21
(1,394 Views)
This is something you need to measure, not compute. Please keep it all in one place. Thanks!
Message 13 of 21
(1,387 Views)
Thank you. Is the Amplitude level and Measurements function inaccurate? Seems to give me terribly inaccurate measurements and the Tone Measurements is even worse.
Message 14 of 21
(1,376 Views)
You have never shown us how the original signal looks like. Maybe your parameters are way off?
As a rule of thumb, the quality of the result of an analysis cannot be better than the quality of the data.
Message 15 of 21
(1,363 Views)
I hope this might help. This is what my extech meter reads and I trust that it's somewhat accurate however, my scope reads quite distant results in terms of the way the waveform looks and the peak to peak value I get using Amplitude and Levels Measurements express vi. Is there anything else I can provide that would help? I'm sending the amp a 100khz signal with an amplitude of 2v.
I'm sorry my phone camera just broke this is the best I can do for right now. My acquisition time is set to .02 which should be equal to 2ms just like the extech.I have set my sample rate to 200k which is double the frequency I'm inputting because otherwise it says I'm sending it 50 khz not 100. Trigger slope is rising just like the extech scope.
Message 16 of 21
(1,338 Views)
These images are useless. Please run your program until data shows on the "analog data" graph. Stop the VI. Right-click the graph...data operations...make current value default. Save VI under a new name and attach it here.
Message 17 of 21
(1,334 Views)
Twice the frequency is the bare minimum you should have set it to.
Make your acquisition rate more like 5 or 10 times the 100 kHz rate.
Twice the frequency means you only get 2 points for each cycle of your signal!
Message 18 of 21
(1,331 Views)
Ok! I changed the sample rate to 100k. Seemed to increase the ptp by a lot. Here is the vi with the saved graph data.
Message 19 of 21
(1,327 Views)
So you have a 100kHz signal sampled at five points per period and it looks like there are higher harmonics. Are you sure the real peak is not between the sampled points? Your p-p is based on 200 peaks. Tell me again why you think you need to do a ptbypt average? This looks nothing like you see on the oscilloscope.
What are you trying to get out of it?
Message 20 of 21
(1,321 Views)
