What is error -1418 on a timed loop?
Has anyone ever gotten error -1418 on the error terminal of timed loop?  It only executes once and I'm trying to run it on a cRIO-9004.
There's nothing in that range listed under the timed loop error codes.
http://zone.ni.com/reference/en-XX/help/371361F-01/lverror/timed_loop_error_codes/
Thanks as always,
Jim
(3,376 Views)
Well, the 1 KHz clock works at the same, relatively low frequency, so I guess I'm not stuck. By the way, this is LabVIEW 2009.
Does the 9004 model only have a 1 KHz clock?  Perhaps that explains what happened.  Maybe someone else will find this helpful someday.
(3,368 Views)
Accepted by topic author Mr._Jim
Hi Jim,
I belive this is what you were looking for:
Timing Sources Available for LabVIEW Timed Loop by Platform
Kristen H.
(3,345 Views)
Kristen,
That's perfect!  I won't believe the GUI next time and will double check.
( Another KB to bookmark )
Thanks a lot,
Jim
(3,337 Views)
