What is this nonsense?
I've made a thousand applications and have never seen this before. Why is my menu garbled? It should be in English.
Message 1 of 17
(698 Views)
The very first thing needs to be checked is the language for non-unicode progs, should be English for your case:
This change will take effect after restart (or logoff/logon).
Message 2 of 17
(685 Views)
Not the problem. My settings are correct.
Message 3 of 17
(641 Views)
OK, if these menu items are you own (loaded from external file), then it could be wrong encoding.
I definitively have seen something similar. Which captions are expected and correct, by the way?
Message 4 of 17
(631 Views)
What version of LabVIEW is that?  The Icon (Top left) looks very old.
"Should be" isn't "Is" -Jay
Message 5 of 17
(597 Views)
V2023 Q1
Message 6 of 17
(586 Views)
 It should look like this. This is a vanilla application with vanilla settings.
Message 7 of 17
(583 Views)
No, it is modern, this is how app from latest LV2024Q3 looks like (don't remember at which version the icon was changed):
I can easily reproduce this "issue" with Cyrillic characters (above is string "Файл(F)" means File(F) in OEM-Cyrillic encoding), but author did't mentioned that other than English chars was used.
Message 8 of 17
(582 Views)
Interesting fact that "File" was converted to <garbage>(F) as well as other standard menu. Looks like something wrong with regional settings and LabVIEW Runtime wrongly detected OS language and turned to Japanese, Korean or Simplified Chinese instead of English - this could explain presence of (F), (E), (O) etc.
Message 9 of 17
(575 Views)
Got this reproduced:
It is Simplified Chinese (and 32-bit LabVIEW, by the way)
Check preferred language setting here:
(For me default menu appeared in German).
Message 10 of 17
(555 Views)
