When is the SEED file required when using the ECU toolkit?
When programming with the ECU toolkit, what is the Seed file used for, and when is it necessary?
Can I omit the Seed file if all I need to do is read from the ECU?
(3,063 Views)
Accepted by sfrosty
Hi sfrosty,
It looks like if your ECU does not implement access restrictions then there is no need to request a seed or use a seed-key DLL.
For a further discussion on this please check out this forum post: https://forums.ni.com/t5/Automotive-and-Embedded-Networks/XCP-ECU-M-amp-C-Toolkit-error-301073/td-p/...
Hope that helps!
(3,028 Views)
I think that last link had an extra space at the end. Here it is again just in case:
(3,026 Views)
Also just as a heads up questions like this are better suited for the AUTOMOTIVE AND EMBEDDED NETWORKS forum: https://forums.ni.com/t5/Automotive-and-Embedded-Networks/bd-p/30
(3,022 Views)
