Why built in mean has side effect on parallel loop
This is simple parallel loop to process mean value of each waveform.
When using Tools->Profile->Find Parallelizable Loops, it says:
This For Loop may or may not be safe to parallelize. Warning(s):
- One or more nodes in the For Loop may have side effects.
So why? Is it non-reentrant?
Message 1 of 14
(4,089 Views)
"May not be safe" does not mean it is unsafe. I think it is safe to parallelize.
Message 2 of 14
(4,080 Views)
Accepted by topic author hongcc1
The Mean function calls an internal NI function, which may (or may not/ be reentrant.  You can always code up your own Mean code easily enough, and could make it reentrant -- that would probably fix your problem.
Message 3 of 14
(4,074 Views)
How about built in filter pallattes? Unlikely to be written by myself.
It also has warning for the side effect. It seems like the Labview profiler has no knowlege whether an internal NI function is reentrant or not.
Is it?
Message 4 of 14
(4,067 Views)
Or it can't tell if it is reentrant. This might be a limitation of the Windows ecosystem.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 5 of 14
(4,030 Views)
Well, it is inlined and reentrant,  and the compiler knows that. 🙂
Are you pressed for performance? How big are the waveforms? You might want to benchmark with/without parallelization to see if the parallelization overhead is actually worth it.
Message 6 of 14
(4,005 Views)
I think it is the DLL call that the tool is worried about.  Not many DLLs out there are actually thread safe.
EDIT: Just looks at the Mean.vi function.  It is NOT reentrant.  Therefore you really could not run many of these in parallel.
GCentral
Message 7 of 14
(3,973 Views)
Well, the diagram shown here is just to simplify my question.
In fact, my concern is how far I can rely on the Labview profiler to tell me a parallelism is safe (or worked) or not.
It seems like conclusion from you guys is warning is the best advice that the profiler can give for those pre-compiled functions.
No direct way (maybe?) to figure out whether they are re-entrant / thread-safe.
Think so.
Message 8 of 14
(3,953 Views)
DLLs, not really.  VIs, open them up and look at the VI Properties->Execution.
GCentral
Message 9 of 14
(3,936 Views)
What LabVIEW version are you using? I checked in both 2013SP1 and 2014SP1 and mean.vi is [reentrant, preallocate clone, inlined]. Seems absolutely safe to parallelize.
Message 10 of 14
(3,920 Views)
