Why is output signal pulled high when stopping program in RT
I'm using 9401 to output a PWM signal. When I run the FPGA program and stop it, nothing unnormal happens. BUT when I run the program through RT using the compiled bitfile and stop, there will be a high level about 110ms.
Here are my FPGA and RT block diagrams of a simple signal output.
I wonder why this could happen? Should I notice any specific when programming the RT?
Thanks in advance
(2,421 Views)
Accepted by GizmoY
You might want to add some logic to make sure  that output goes low when the stop is set to TRUE inside of your Single Cycle Timed Loop.  My guess is that you are just seeing a delay between when the FPGA is commanded to stop and when the bit file is actually closed and the FPGA is reset.
GCentral
(2,388 Views)
Thanks for your kind reply
Finally figure it out
According to your statement, I viewed the help. There is indeed a reset. I can discard it by right clicking the 'close FPGA VI reference', which needs to add additional logic to set output low in FPGA program
(2,377 Views)
