Windows 11 Home and LabView
Hi.
I tried to connect several instruments (Ex: Agilent 8453 UV/Vis spectrophotometer) to LabVIEW2021 on my PC with Windows 11 Home edition. But, none of the instruments show up in NI-MAX. Please help.
Message 1 of 8
(1,920 Views)
Please ensure you've installed NI-VISA drivers. BTW, how are you connecting the instruments to the laptop? over USB-GPIB or USB or TCP?
Santhosh
Soliton Technologies
Message 2 of 8
(1,886 Views)
Hi Santhosh.
Thank you for your response.
I'm using GPIB-USB which worked for a PC with Windows 7. And yes, I had NI VISA installed.
Message 3 of 8
(1,838 Views)
Do you also have the NI 488.2 drivers installed?
Message 4 of 8
(1,834 Views)
Yes Gregory.
Message 5 of 8
(1,771 Views)
the LabVIEW Readme file 2021 indicate that the windows version compatible with LabVIEW 2021 are (Windows 10 ,Windows Server 2019,Windows Server 2016 ) so Windows 11 is not indicated in the List.
https://www.ni.com/pdf/manuals/374715r.html
Message 6 of 8
(1,754 Views)
@Zhulfaa wrote:
Hi Santhosh.
Let's look at that hardware one more time and get a specific model number since many older NI GPIB-USB devices have become quite obsolete.  Unless that is really a GPIB-USB HS or HS+ it's probably not going to have modern driver support in NI VISA .  The GBIB-USB A dropped support many years ago an currently the only searches returning for GPIB-USB B devices run into archives that NI hasn't got around to transitioning to the newer documentation database.
The ReadMe file for your exact version of NI VISA will contain a list of supported hardware.  One day someone should change that title to "ReadMeYesIAmReallySerious"
"Should be" isn't "Is" -Jay
Message 7 of 8
(1,743 Views)
As Jay pointed out, and I found out the hard way last week, NI GPIB-USB-B are not suported by NI-VISA drivers >version 17.6  See this article, https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g0uXSAQ&l=en-CA
Craig
Message 8 of 8
(1,620 Views)
