Windows occasionally stop redrawing
Theo,
Was the date that did show up being updated by a property node, or a wire? In our case, even when we updated the values of indicators (using wires), the page would not refresh, so sounds like it might be a related issue, but not exactly the same.
Message 31 of 34
(475 Views)
Just a nitpick but one which might have some serious impact depending on LabVIEW version and how often you intend to switch between the/a subpanel and your main screen. You use an Open VI Reference for the main screen but never close the reference. While the panel of course only can exist once in a specific application context (disregarding reentrant VIs, as that would not make sense for a main UI), the reference returned is at least in older LabVIEW versions (not sure about 2013) a unique object that consumes a small but nevertheless existing memory amount for every single reference. And if this VI is not called in the context of a top level hierarchy that is going to be idle after this, this reference stays allocated until you close your application (or LabVIEW runs into an out of memory/refnum situation which tends to terminate the application rather disgracefully).
Rolf Kalbermatter
My Blog
Message 32 of 34
(461 Views)
Thanks for the comment
Theo
Message 33 of 34
(427 Views)
Hi Wolfskill,
The time indicator is part of the a hype-cluster structure which contains various indicators. The cluster's value is written by wire.
The button seen near the bottom of the image is part of a different cluster of controls and its colour is updated by reference of course.
Message 34 of 34
(412 Views)
